MasterLiquid Atmos II Pro Gold Limited Edition image number 0
MasterLiquid Atmos II Pro Gold Limited Edition image number 1
MasterLiquid Atmos II Pro Gold Limited Edition image number 2
MasterLiquid Atmos II Pro Gold Limited Edition image number 3
MasterLiquid Atmos II Pro Gold Limited Edition image number 4
MasterLiquid Atmos II Pro Gold Limited Edition image number 5
MasterLiquid Atmos II Pro Gold Limited Edition image number 6
MasterLiquid Atmos II Pro Gold Limited Edition image number 7
Performance, Refined in Gold.
• Only 1,999 Individually Numbered Units Worldwide
• Upgraded G9B V2 Dual-Chamber Pump
• Three Premium MasterFan A120 Gold Fans
• Customizable Magnetic Covers with Signature 3D Mesh Gold
ONLY 1,999 WILL EVER EXIST
Limited to just 1,999 individually numbered units worldwide, each Atmos II Pro GOLD carries its own unique production number.
1 of 1,999.
UPGRADED G9B V2 PUMP
Refined From the Inside Out.
The upgraded G9B V2 pump combines a dual-chamber design, copper cold plate, and low-profile architecture for efficient coolant circulation and dependable CPU cooling.
PREMIUM METAL. SERIOUS AIRFLOW.
MasterFan A120 Gold x 3
Three aluminum MasterFan A120 Gold fans deliver strong radiator airflow at up to 2500 RPM ±10%, with a rated noise level of approximately 27 dB(A).
*Tested by Cooler Master Lab. Results may vary by system configuration/
MAKE IT YOURS
Magnetic Covers. Instant Customization.
Quickly switch between 3D Mesh Gold, metallic finish, and VRM fan covers. The signature 3D Mesh Gold cover pairs a dimensional mesh surface with a gold frame for a distinctive premium finish.
ACTIVE VRM COOLING
Cooling Beyond the CPU.
The optional VRM fan cover directs airflow toward nearby motherboard components, helping reduce temperatures around the CPU power-delivery area by up to 13°C under test conditions.
OPTIMIZED FOR INTEL AND AMD
Put Cooling Closer to the Hotspot.
Dedicated offset mounting positions the cold plate closer to modern CPU hotspots on supported Intel and AMD platforms.
Intel LGA 1851 / 1700 / 1200 / 115x AMD AM5 / AM4
6-YEAR WARRANTY
Built With Long-Term Confidence.
Atmos II Pro GOLD is backed by a 6-year Cooler Master warranty, giving you long-term confidence in your cooling system.
ENGINEERED FROM WITHIN
Every Detail. Built to Perform.
From the upgraded G9B V2 pump to the copper cold plate and integrated vibration damping, Atmos II Pro GOLD brings precision engineering together for powerful cooling and smoother operation.
  • Product Name MasterLiquid Atmos II Pro GOLD Limited Edition
  • Product number MLX-D36M-A25TK-R1
  • CPU platform support - Intel Intel® LGA 1851 / 1700 / 1200 / 1150 / 1151 / 1155 / 1156 / socket
  • CPU platform support - AMD AMD® AM5 / AM4 socket + offset bracket
  • Pump Dimensions 92.5 x 87 x 39 mm (3.6 x 3.4 x 1.5 inch)
  • Radiator - Material Aluminum
  • Radiator - Dimensions (LxWxH) 394 x 119.2 x 27 mm (15.5 x 4.7 x 1.1 inch)
  • Water pipes - Length 400 mm
  • Pump - Noise levels(Max) 25 dB(A)
  • Pump - Features Non-LED
  • Pump - Speed 3400 ± 300 RPM
  • Pump - MTTF > 210,000 hours
  • Pump - Rated voltage 12 VDC
  • Pump - Power 3.84 W
  • Pump - Connector 3-Pin ARGB + 4-Pin PWM
  • Flex-Kit - Name VRM Fan
  • Flex-Kit - Color Black
  • Flex-Kit - Dimensions 85.0 x 78.5 x 25.5 mm (3.4 x 3.1 x 1 inch)
  • Flex-Kit - Features NON LED
  • Flex-Kit - Quantity(pcs) 1 PCS
  • Flex-Kit - Wire length 1000 mm
  • Flex-Kit - Speed 690 ~ 4000 ± 10% RPM
  • Flex-Kit - Airflow(Max) 15.8 m³/h (9.3 CFM)
  • Flex-Kit - Air Pressure(Max) 2.8 mmH₂O
  • Flex-Kit - Noise levels(Max) 36 dB(A)
  • Flex-Kit - MTTF > 50,000 hours
  • Flex-Kit - Bearings Dynamic-Loop Bearing
  • Flex-Kit - Connector 4-Pin PWM
  • Flex-Kit - Rated voltage 12 VDC
  • Flex-Kit - Rated current 0.15 A
  • Flex-Kit - Safe current 0.25 A
  • Flex-Kit - Power 1.8 W
  • Fan - Dimensions 120 x 120 x 30 mm (4.8 x 4.8 x 1.18 inch)
  • Fan - Features Non-LED
  • Fan - Quantity(pcs) 3 PCS
  • Fan - Speed 0 ~ 2300 RPM± 10%
  • Fan - Airflow(Max) 80.69 CFM
  • Fan - Air Pressure(Max) 6.1 mmH2O
  • Fan - Noise levels(Max) 29.7 dB(A)
  • Fan - MTTF > 200,000 hours
  • Fan - Bearings Dual-ball Bearing
  • Fan - Connector 4-Pin PWM
  • Fan - Rated voltage 12 VDC
  • Fan - Rated current 0.17 A
  • Fan - Safe current 1 A
  • Fan - Power 2.04 W
  • Warranty 6 years
