M2000 Platinum image number 0
M2000 Platinum image number 1
M2000 Platinum image number 2
M2000 Platinum image number 3
M2000 Platinum image number 4
M2000 Platinum image number 5
M2000 Platinum image number 6
M2000 Platinum image number 7
M2000 Platinum image number 8
M2000 Platinum
M2000 Platinum
M2000 Platinum
M2000 Platinum
M2000 Platinum
M2000 Platinum
M2000 Platinum
M2000 Platinum
M2000 Platinum
Full-Modular 80 PLUS Platinum Certified High Wattage ATX PSU
M2000 Platinum
2000W Maximum Load
135mm silent Fan
Full-Modular Cabling
7 Year Warranty
  • Category Above 750W
  • EPS 4+4 Pin Connectors 2
  • Series M Series
  • 80 Plus Efficiency Platinum
  • SATA Connectors 12
  • Fan Size 135mm
  • Protections OVP
  • Fan Bearing DBB
  • Operating Temperature 50°C
  • ATX Version ATX 12V V2.52
  • 80 PLUS Rating 80 PLUS Platinum EU 230V
  • PCI-e 6+2 Pin Connectors 18
  • Protections OPP
  • Protections SCP
  • Protections UVP
  • Protections OTP
  • Fan Speed 2400 RPM
  • Protections OCP
  • Hold Up Time >16ms
  • Protections Surge and Inrush Protection
  • Input Voltage 200-240V
  • Efficiency 94% @ Typical Load
  • Regulatory CCC
  • Regulatory CE
  • Input Current 12A
  • Regulatory EAC
  • Regulatory cTUVus
  • Regulatory TUV
  • Regulatory RoHS2.0
  • Regulatory BIS
  • Regulatory UKCA
  • Model MPZ-K001-AFFBP
