Addressable RGB LED Tube Sleeve A1 image number 0
Addressable RGB LED Tube Sleeve A1 image number 1
Addressable RGB LED Tube Sleeve A1 image number 2
Addressable RGB LED Tube Sleeve A1 image number 3
Addressable RGB LED Tube Sleeve A1 image number 4
Addressable RGB LED Tube Sleeve A1 image number 5
Addressable RGB LED Tube Sleeve A1 image number 6
Addressable RGB LED Tube Sleeve A1 image number 7
Addressable RGB LED Tube Sleeve A1 image number 8
Addressable RGB LED Tube Sleeve A1 image number 9
Cooler Master’s Addressable RGB LED Tube Sleeve is our first developed sleeve designed to spice up the look of your liquid cooler tubing.
  • LED Quantity 30 pcs
  • Quantity 2 pcs
  • Connector 3-Pin ARGB
  • Rated Voltage 5 VDC
  • Length 330mm / 13 inch
  • Color White
  • Diameter 10mm, 12mm
  • Cooler Type RGB Accessories
  • Material Rubber
  • Rated Current 0.45A
  • Power Consumption 2.25W
  • Weight 57g / 0.13 lbs, 67g / 0.15 lbs
  • Product Number MFX-ATHN-10NNN-R1, MFX-ATHN-12NNN-R1
