Killer 103 image number 0
Killer 103 image number 1
Killer 103 image number 2
Killer 103 image number 3
Killer 103 image number 4
Killer 103
Killer 103
Killer 103
Killer 103
Killer 103
Killer 103
  • Model Number RC-103-KKN1-TW
  • Color(s) Black
  • Materials Plastic bezel with mesh, steel case body
  • Dimensions (L x W x H) 397.27 x 183 x 415.8 mm
  • Motherboard Support Mini-ITX, Micro-ATX, ATX
  • 5.25" Drive Bays 1 (The max. length of 5.25" device: 170mm / 6.7")
  • 3.5" Drive Bays 3 (hidden)
  • 2.5" Drive Bays 2 (hidden, in the HDD cage)
  • Expansion Slots 7
  • I/O Panel - USB Ports 1x USB 3.0, 1x USB 2.0
  • I/O Panel - Audio In / Out 1x Audio (supports AC97 Only)
  • Fan Support - Front 1x 120mm Black Fan
  • Fan Support - Rear 1x 120mm Black Fan (Optional)
  • Fan Support - Side 2x 120mm Fan (Optional)
  • Clearance - CPU Cooler 160mm (w/o 12025 mm Side Fan), 135mm (with 12025 mm Side Fan)
  • Clearance - Graphics Card 345mm (w/o 12025 mm Front Fan), 320mm (with 12025 mm Front Fan)
  • Motherboard Support ATX PS2 (Max. length: 180 mm)
  • Size Mid Tower
  • Series Others
