JetFlo 120
JetFlo 120
Fan Rated Voltage12 VDC
LegacyCooling
Fan Power Connector4-Pin (PWM)
Cooler TypeCase Fan
Fan Bearing TypePOM Bearing - Cooler Master 4th Gen. bearing (*POM: Polyoxymethelene)
Fan Life Expectancy160,000 Hours
LED ColorDark (No LED)
AccessorySilent Mode Adapter x 2 (1600 RPM x 1, 1200 RPM x 1)
AccessoryMetal Screw x 4
Fan Noise Level12 - 36 dBA (PWM)
Fan Noise Level19 dBA (@1200 RPM w/ silent mode adapter)
Fan Rated Current0.4A
Fan Power Consumption4.8W
Fan Noise Level28 dBA (@1600 RPM w/ silent mode adapter)
Fan Air Pressure2.72 mmH2O ± 10%
Fan Speed800-2000 RPM (PWM) ± 10%
Fan Speed1200-1600 RPM (w/ silent adapter)
Fan Airflow95 CFM ± 10%
Product NumberR4-JFNP-20PK-R1 (Dark, No LED)
