Internal to External USB 3.0 Adapter (2 ports) image number 0
  • Weight 42 g / 0.09 lb
  • I/O Panel 2x USB 3.0 internal ports
  • Compatible with HAF 912 Advanced
  • Compatible with CM 690 II Advanced
  • Legacy Accessories
  • Compatible with CM Storm Enforcer
  • Accessories Miscellaneous
  • Series Others
  • Dimensions (L x W x H) 280mm / 11.02 inch
  • Model Number RA-USB-3002-IN
