I70 for LGA 1700 image number 0
I70 for LGA 1700 image number 1
I70 for LGA 1700 image number 2
I70 for LGA 1700
I70 for LGA 1700
I70 for LGA 1700
Strong Airflow Low Noise
I70 for LGA 1700
I70 for LGA 1700 is our popular I70 standard cooler designed for Intel LGA 1700 sockets.
STANDARD COOLER I70
Compact design perfectly fits All-in-One systems or limited form factor cases. Aluminum fins provide excellent heat dissipation. 120mm diameter fan with long life expectancy, durable materials, strong airflow, and low noise output.
650~1800
RPM ± 10%
Fan speed
37
CFM ± 10%
Air volume
1.33mm
H2O ± 10%
Wind pressure
  • Product Number RR-I7A7-18FK-N1
  • CPU Socket LGA1700
  • Heat Sink Material Aluminum
  • Dimensions (L x W x H) 120 x 120 x 70 mm / 4.7 x 4.7 x 2.7 inch
  • Fan Speed 1800 RPM ± 10%
  • Fan Airflow 37 CFM (Max)
  • Fan Air Pressure 1.33 mmH2O (Max)
  • Fan Noise Level 28 dBA (Max)
  • Fan MTTF >40,000 Hours
  • Fan Connector 3-Pin PWM
  • Fan Rated Current 0.1A
  • Fan Safety Current 0.16A
  • Fan Power Consumption 1.2W
  • Cooler Type Standard Cooler
  • Series Standard
