Global Headquarters
Strong Airflow Low Noise
I70 for LGA 1700 is our popular I70 standard cooler designed for Intel LGA 1700 sockets.
Compact design perfectly fits All-in-One systems or limited form factor cases. Aluminum fins provide excellent heat dissipation. 120mm diameter fan with long life expectancy, durable materials, strong airflow, and low noise output.
