Global Headquarters
Strong Airflow Low Noise
I50 for LGA 1700 CPU Cooler
I50 is a newly designed air cooler that compatible with intel LGA 1700 sockets. 60.8mm super thin design perfectly fits All-in-One systems or limited form factor cases. Aluminum fins provide excellent heat dissipation. 92mm diameter fan with long life expectancy, durable materials, strong airflow, and low noise output.
