Hyper TX3 (Fan Bracket Version) image number 0
Hyper TX3 (Fan Bracket Version) image number 1
Hyper TX3 (Fan Bracket Version) image number 2
Hyper TX3 (Fan Bracket Version) image number 3
Hyper TX3 (Fan Bracket Version) image number 4
Hyper TX3 (Fan Bracket Version) image number 5
Hyper TX3 (Fan Bracket Version) image number 6
Hyper TX3 (Fan Bracket Version) image number 7
Hyper TX3 (Fan Bracket Version) image number 8
The launch of Hyper TX3 marks another milestone with Cooler Master’s first-ever air cooler fully compatible with Intel LGA 1156 socket type.
  • Fan MTTF 40,000 Hours
  • Legacy Cooling
  • Fan Bearing Type Long Life Sleeve Bearing
  • Weight 470g
  • Fan Airflow 15.7 - 54.8 CFM ± 10%
  • Fan Dimensions (L x W x H) 92 x 92 x 25 mm / 3.6 x 3.6 x 1 inch
  • CPU Socket LGA1200
  • Fan Speed 800-2800 RPM (PWM) ± 10%
  • CPU Socket LGA1156
  • CPU Socket LGA1155
  • Fan Air Pressure 0.35 - 4.27 mmH2O ± 10%
  • Heat Sink Material 3 Heat Pipes
  • CPU Socket LGA1151
  • CPU Socket LGA1150
  • CPU Socket LGA775
  • Heat Sink Dimensions (L x W x H) 90 x 51 x 136 mm / 3.5 x 2.0 x 5.4 inch
  • CPU Socket AM4
  • CPU Socket AM3+
  • CPU Socket AM3
  • CPU Socket AM2
  • CPU Socket FM2+
  • CPU Socket FM2
  • CPU Socket FM1
  • CPU Socket 940
  • CPU Socket 939
  • CPU Socket 754
  • Product Number RR-910-HTX3-G1
  • Fan Noise Level 17 - 35 dBA
