Hyper T200 image number 0
Hyper T200 image number 1
Hyper T200 image number 2
Hyper T200 image number 3
Hyper T200 image number 4
Hyper T200 image number 5
Hyper T200 image number 6
Hyper T200 image number 7
Hyper T200
Hyper T200
Hyper T200
Hyper T200
Hyper T200
Hyper T200
Hyper T200
Hyper T200
Small Yet Powerful
Hyper T200
Hyper T200 is a CPU cooler with high efficiency and low sound suppression made by CoolerMaster. Buckle installation is easy to install and remove.
  • Color Silver
  • Cooler Type Air Cooler
  • Heatpipes 2
  • Fan Bearing Type LDB
  • Series Hyper
  • CPU Socket LGA1700
  • Fan Dimensions (L x W x H) 92 x 92 x 25 mm / 3.6 x 3.6 x 1 inch
  • Fan Speed 800-2200 RPM (PWM) ± 10%
  • CPU Socket LGA1200
  • CPU Socket LGA1156
  • Fan MTTF >40,000 Hours
  • CPU Socket LGA1155
  • CPU Socket LGA1151
  • CPU Socket LGA1150
  • Heat Sink Material 2 Heat Pipes
  • Fan Safety Current 0.24A
  • CPU Socket AM5
  • CPU Socket AM4
  • Heat Sink Material Direct Contact
  • Fan Power Consumption 2.4W
  • Fan Rated Current 0.2A
  • Note AM5 and LGA 1700 mounting kits are included from New Package Design. You may obtain the required mounting kits for products with older package design through the CM store, regional resellers or distributors. Older CPU sockets (LGA 2066, LGA2011-v3, LGA2011, LGA1366, AM3+, AM3, AM2+, AM2, FM2+, FM2, FM1) will not be supported anymore from New Package Design.
  • Fan Air Pressure 1.2 mmH2O
  • Fan Noise Level 31.2 dBA
  • Dimensions (L x W x H) 102 x 84.5 x 136 mm / 4.0 x 3.3 x 5.3 inch
  • Fan Airflow 43.25 CFM (Max)
  • Product Number RR-T200-22PK-R1
