Hyper T20 image number 0
Hyper T20 image number 1
Hyper T20 image number 2
Hyper T20 image number 3
Hyper T20 image number 4
Hyper T20 image number 5
Hyper T20 image number 6
Hyper T20 image number 7
Hyper T20 image number 8
Hyper T20
Hyper T20
Hyper T20
Hyper T20
Hyper T20
Hyper T20
Hyper T20
Hyper T20
Hyper T20
Small Yet Powerful
Hyper T20
Hyper T20 is a CPU cooler with high efficiency and low sound suppression. Buckle installation is easy to install and remove.
  • Heat Pipe Dimensions Ø6mm
  • Cooler Type Air Cooler
  • Fan MTTF 40,000 Hours
  • Fan Safety Current 0.16A
  • Fan Power Connector 3-Pin
  • Heatpipes 2
  • Fan Bearing Type LDB
  • Series Hyper
  • CPU Socket LGA1200
  • CPU Socket LGA1156
  • CPU Socket LGA1155
  • CPU Socket LGA1151
  • CPU Socket LGA1150
  • Heat Sink Material 2 Heat Pipes
  • CPU Socket LGA775
  • CPU Socket AM4
  • CPU Socket AM3+
  • CPU Socket AM3
  • Heat Sink Material Direct Contact
  • CPU Socket AM2
  • CPU Socket FM2+
  • CPU Socket FM2
  • CPU Socket FM1
  • Heat Sink Weight 218g / 0.48lb
  • Heat Sink Dimensions (L x W x H) 80 x 40 x 117 mm / 2.6 x 1.3 x 3.8 inch
  • Fan Speed 2000 RPM ± 10%
  • Fan Dimensions (L x W x H) 95.5mm x 25 mm *1 Pcs / 3.1 x 0.8 x 1 inch
  • Fan Noise Level 30 dBA
  • Fan Air Pressure 1.09 mmH2O
  • Dimensions (L x W x H) 95 x 80 x 117 mm / 3.1 x 2.6 x 3.8 inch
  • Fan Airflow 31.7 CFM ± 10%
  • Product Number RR-T20-20FK-R1
