Hyper H410R White Edition image number 0
Hyper H410R White Edition image number 1
Precise Air Flow
Direct Contact Technology
XtraFlo PWM Fan
Compact Size
Snap and Play
4 heatpipes with Exclusive Direct Contact Technology providing effective and excellent heat dissipation
XtraFlo PWM Fan
Comes with white LEDs and wide speed range can be fine-tuned for maximum cooling performance or silent operation
Precise Air Flow
Precise stacked fin array decreases airflow resistance which allows for cooler air flow into the heatsink
  • Product Number RR-H41W-20PW-R1
  • Exterior Color Silver
  • Dimensions (L x W x H) 102 x 84.5 x 136 mm / 4.0 x 3.3 x 5.3 inch
  • Fan Dimensions (L x W x H) 92 x 92 x 25 mm / 3.6 x 3.6 x 1 inch
  • Fan Profiles White
  • Fan Quantity 1 PC
  • Fan Speed 600-2000 RPM (PWM) ± 10%
  • Fan Airflow 34.73 CFM (Max)
  • Fan MTTF >40,000 Hours
  • Fan Noise Level 29.38 dBA (Max)
  • Fan Rated Current 0.19A
  • Fan Safety Current 0.4A
  • Fan Power Consumption 2.28W
  • Cooler Type Air Cooler
  • Series Hyper
  • Heatpipes 4
  • Note AM5 and LGA 1700 mounting kits are included from New Package Design. You may obtain the required mounting kits for products with older package design through the CM store, regional resellers or distributors. Older CPU sockets (LGA 2066, LGA2011-v3, LGA2011, LGA1366, AM3+, AM3, AM2+, AM2, FM2+, FM2, FM1) will not be supported anymore from New Package Design.
