CPU COMPATIBILITY
With RGB LED PWM Fan
Precise Air Flow
Direct Contact Technology
XtraFlo PWM Fan
Compact Size
Snap and Play
The wired RGB LED controller allows for customizable colors and effects with just the touch of a button
4 heat pipes with Exclusive Direct Contact Technology providing effective and excellent heat dissipation
Precise stacked fin array decreases airflow resistance which allows for cooler air flow into the heatsink
Tool-free mounting system ensures hassle-free installation. Universal retention brackets are compatible with latest Intel and AMD socket CPU.
