Hyper 620S image number 0
Hyper 620S image number 1
Hyper 620S image number 2
Hyper 620S image number 3
Hyper 620S image number 4
Hyper 620S
Hyper 620S
Hyper 620S
Hyper 620S
Hyper 620S
Hyper 620S
Automatic ARGB
Controllable lighting
Dual tower heat sink
6 nickel-plated heat pipes
Minimal height
High-performance Cryofuze
Controllable Lighting
Automatic ARGB
Intuitive LED detection automatically provides default ARGB spectrum lighting.
6 Nickel-plated Heat Pipes
Uniform heat pipes featuring a nickel-plated base with complete coverage for even, efficient heat transfer.
Dual Tower Heat Sink
Minimal Height
Compatible with most case requirements thanks to low-profile heat pipes and a total height of 154.9mm.
  • Product Number RR-D6NA-17PA-R1
  • Exterior Color Black/Silver
  • Dimensions (L x W x H) 125 x 137 x 154.9 mm
  • Heat Sink Material 6 Heat Pipes / Aluminum Fins
  • Fan Dimensions (L x W x H) 120 x 120 x 25mm
  • Fan Quantity 2 PCS
  • Fan Speed 650-1750 RPM ± 10%
  • Fan Airflow 71.93 CFM (Max)
  • Fan MTTF >160,000 Hours
  • Fan Noise Level 27.2 dBA
  • Fan Rated Current 0.26A
  • Fan Safety Current 0.37A
  • Fan Power Consumption 3.12W
  • Cooler Type Air Cooler
  • Series Hyper
  • Heatpipes 6
