Global Headquarters
Six SCHP design for better heat dissipation
Patented Superconductive Composite Heat Pipes
Available in Black and White colorations
Dual Mobius 120P fans included
The Cooler Master Hyper 612 Apex is a high-performance air cooler engineered for builders who demand raw cooling power without compromise. It features six patented Superconductive Composite copper heat pipes and dual Mobius 120P PWM fans for efficient heat dissipation and quiet operation, even under heavy loads. With support for AMD AM5/AM4 and Intel LGA 1851/1700 sockets, the 612 Apex delivers broad compatibility across modern platforms. Its 159mm height fits most mid-tower cases, while the clean top cover and color options (Black or White) make it a perfect match for performance-focused, visually refined builds. No gimmicks—just pure cooling muscle.
Six advanced copper heat pipes deliver fast, even heat transfer from modern high-core CPUs.
Pressure-optimized fans with Loop Dynamic Bearings for silent, high-performance airflow under load.
Compact enough to fit most mid-tower cases without sacrificing performance or clearance.
Available in Black or White to match your build, with premium finish and clean aesthetics.
Supports AMD AM5/AM4 and Intel LGA 1851/1700 out of the box for next-gen readiness.
Tool-free brackets and streamlined mounting make setup fast, clean, and frustration-free.
Built to last and backed by Cooler Master's industry-leading support and reliability guarantee.
