Global Headquarters
Small Space. Big Impact.
• 67mm Golden Height
• Acclaimed Slim Fan - Mobius 120 Slim
• All-Black Tower
• Outstanding Heat Dissipation
The Hyper 510 delivers powerful cooling performance in a remarkably compact form. With an overall height of just 67mm, its top-flow design is purpose-built for ITX cases where space is limited. Five direct-contact heat pipes and an all-black heatsink tower provide efficient heat dissipation while helping cool surrounding components. Paired with the acclaimed Mobius 120 Slim fan, the Hyper 510 balances high-speed airflow, reliable thermal performance, and quiet operation in a compact package.
With a total height of just 67mm, the Hyper 510 combines a top-flow heatsink design with a slim 12015 fan to fit the vast majority of ITX cases. Its compact profile delivers capable cooling performance without compromising valuable build space.
Slim Profile. Powerful Airflow.
Equipped with the Mobius 120 Slim fan, the Hyper 510 delivers high-speed cooling in a slim 15mm frame. Reaching up to 2500 RPM and 53.7 CFM of airflow, it maintains consistent and reliable cooling performance while keeping noise levels low.
Stealthy Looks. Lasting Performance.
The heatsink tower features an all-black baked-paint finish that enhances its refined appearance to adapt your builds. Paired with five direct-contact heat pipes, it delivers stable, long-lasting heat dissipation.
Ready for Your Platform.
Supporting Intel LGA 1851, 1700, 1200, 1151, 1150, 1155, and 1156, as well as AMD AM5 and AM4 sockets, the Hyper 510 offers broad compatibility across modern Intel and AMD desktop platforms.
Built to Last.
Featuring a Mobius 120 Slim fan with a loop dynamic bearing rated for over 200,000 hours of MTTF, the Hyper 510 is designed for dependable long-term operation. Backed by a 3-year warranty, it provides lasting cooling confidence for compact builds.
