Hyper 412 PWM image number 0
Hyper 412 PWM image number 1
Hyper 412 PWM image number 2
Hyper 412 PWM image number 3
Hyper 412 PWM image number 4
Hyper 412 PWM
Hyper 412 PWM
Hyper 412 PWM
Hyper 412 PWM
Hyper 412 PWM
Hyper 412 PWM
Hyper 412 PWM
  • Heat Pipe Dimensions Ø6mm
  • Note *AMD AM4 upgrade kit needed, please visit: http://bit.ly/31244ne
  • Cooler Type Air Cooler
  • Fan MTTF 40,000 Hours
  • Legacy Cooling
  • Fan Bearing Type Long Life Sleeve Bearing
  • CPU Socket LGA2066
  • CPU Socket LGA2011-v3
  • Note *The supplied accessories may differ by country or area. Please check with your local distributor for further details.
  • Series Hyper
  • Fan Speed 600-2000 RPM (PWM) ± 10%
  • CPU Socket LGA1366
  • CPU Socket LGA1156
  • CPU Socket LGA1155
  • CPU Socket LGA1151
  • CPU Socket LGA1150
  • Heat Sink Dimensions (L x W x H) 128 x 70 x 160 mm / 5.0 x 2.8 x 6.3 inch
  • Fan Noise Level 9 - 36 dBA
  • Fan Weight 104g / 0.23lb
  • Fan Airflow 24.9 - 82.9 CFM ± 10%
  • Fan Air Pressure 0.3 - 2.7 mmH2O ± 10%
  • Heat Sink Weight 538g / 1.19lb
  • Dimensions (L x W x H) 132 x 99 x 160mm / 5.2 x 3.9 x 6.3 inch
  • CPU Socket AM4
  • CPU Socket AM3+
  • CPU Socket AM3
  • CPU Socket AM2+
  • CPU Socket AM2
  • CPU Socket FM2+
  • Heat Sink Material 4 Continuous Direct Contact Heat Pipes
  • CPU Socket FM2
  • CPU Socket FM1
  • Fan Power Consumption 2.64W
  • Product Number RR-H412-20PK-R1
  • Fan Rated Current 0.22A
  • Fan Dimensions (L x W x H) 120 x 120 x 25mm
