Hyper 411 Nano ARGB image number 0
Hyper 411 Nano ARGB image number 1
Hyper 411 Nano ARGB image number 2
Hyper 411 Nano ARGB
Hyper 411 Nano ARGB
Hyper 411 Nano ARGB
Compact Cooler, High Performance
Hyper 411 Nano ARGB
Direct contact technology
All black aesthetic
AMD and Intel compatibility
Easy fan mount
HYPER 411 NANO ARGB
HYPER 411 NANO ARGB
Introducing a new edition to Cooler Master’s Hyper air cooler series, 411 NANO ARGB.
Hyper 411 NANO brings a crop of excellent features to round out the already cutting edge performance of the Hyper series With direct contact technology for ultra rapid heat transfer, an all black aesthetic, wide ranging compatibility with both Intel and AMD CPU’s, and including clips for easy fan mounting.
4 heat pipes with direct contact ensure more efficient heat transfer from the CPU to the cooler, enhancing cooling performance.
Easy fan mount
Easily mount fan simplifies the installation process. This allows users to attach and detach the fan quickly, making maintenance and upgrades hassle-free
Improved mounting ensures compatibility with the latest AMD and Intel CPU sockets.
All black aesthetic
An all-black aesthetic gives it a sleek and stylish look, making it a great match for any build focused on a minimalist or stealthy design.
  • Product Number RR-H410-25PA-R1
  • Color Black
  • Dimensions (L x W x H) 102 x 85 x 136 mm / 4.0 x 3.2 x 5.3 inch
  • Fan Size 92mm
  • Fan Quantity 1 PC
  • Fan Speed 650-2500 RPM (PWM) ± 10%
  • Fan Airflow 43.59 CFM (Max)
  • Fan Pressure 3.25 mmH₂O (Max)
  • Fan MTTF >160,000 Hours
  • Fan Bearing LDB
  • Fan Rated Current 0.14A
  • Fan Safety Current 0.18A
  • Fan Power Consumption 1.68W
  • Fan Dimensions (L x W x H) 92 x 92 x 25.4 mm / 3.6 x 3.6 x 1 inch
  • Series Hyper
  • Fan Size 92
  • Heatpipes 4
  • Cooler Type Air Cooler
