Hyper 212 Spectrum V2 CPU Air Cooler image number 0
Hyper 212 Spectrum V2 CPU Air Cooler image number 1
Hyper 212 Spectrum V2 CPU Air Cooler image number 2
Hyper 212 Spectrum V2 CPU Air Cooler image number 3
Hyper 212 Spectrum V2 CPU Air Cooler image number 4
Hyper 212 Spectrum V2 CPU Air Cooler image number 5
Hyper 212 Spectrum V2 CPU Air Cooler image number 6
Hyper 212 Spectrum V2 CPU Air Cooler image number 7
The Hyper 212 Spectrum V2 delivers both optimal balance of airflow and performance.
  • Cooler Type Air Cooler
  • Fan Quantity 240: 2 PCS | 360: 3PCS
  • Fan Bearing Type LDB
  • Heatpipes 4
  • Fan Safety Current 0.37A
  • Series Hyper
  • CPU Socket LGA1700
  • CPU Socket LGA1200
  • Fan MTTF >160,000 Hours
  • CPU Socket LGA1156
  • CPU Socket LGA1155
  • Heat Sink Material 4 Heat Pipes
  • CPU Socket LGA1151
  • Color Black & Silver
  • CPU Socket LGA1150
  • CPU Socket AM5
  • CPU Socket AM4
  • Fan Rated Current 0.21A
  • Note AM5 and LGA 1700 mounting kits are included from New Package Design. You may obtain the required mounting kits for products with older package design through the CM store, regional resellers or distributors. Older CPU sockets (LGA 2066, LGA2011-v3, LGA2011, LGA1366, AM3+, AM3, AM2+, AM2, FM2+, FM2, FM1) will not be supported anymore from New Package Design.
  • Fan Power Consumption 2.52W
  • Fan Air Pressure 2.5 mmH2O (Max)
  • Fan Noise Level 27 dBA (Max)
  • Fan Speed 650-1800 RPM ± 5%
  • Dimensions (L x W x H) 120 x 80.5 x 157 mm / 4.7 x 3.2 x 6.2 inch
  • Fan Airflow 62 CFM (Max)
  • Product Number RR-2V2L-18PD-R1
