Hyper 212 RGB image number 0
Hyper 212 RGB image number 1
Hyper 212 RGB image number 2
Hyper 212 RGB image number 3
Hyper 212 RGB image number 4
Hyper 212 RGB image number 5
Hyper 212 RGB image number 6
Hyper 212 RGB image number 7
Hyper 212 RGB
Hyper 212 RGB
Hyper 212 RGB
Hyper 212 RGB
Hyper 212 RGB
Hyper 212 RGB
Hyper 212 RGB
Hyper 212 RGB
Designed To Sync With Motherboard RGB Software
Hyper 212 RGB
The Hyper 212 RGB maintains the same cooling efficiency as the Hyper 212 LED. The Direct Contact Technology, stacked fins and 4 heatpipes...
  • Cooler Type Air Cooler
  • CPU Socket LGA2066
  • CPU Socket LGA2011-v3
  • Fan MTTF 160,000 Hours
  • Fan Safety Current 0.37A
  • Series Hyper
  • CPU Socket LGA1366
  • CPU Socket LGA1156
  • Fan Rated Current 0.12A
  • Fan Power Consumption 1.44W
  • Heat Sink Material 4 Heat Pipes
  • CPU Socket LGA1155
  • CPU Socket LGA1151
  • CPU Socket LGA1150
  • CPU Socket LGA775
  • CPU Socket AM4
  • CPU Socket AM3+
  • Heat Sink Material Direct Contact
  • CPU Socket AM2+
  • CPU Socket AM2
  • CPU Socket FM2+
  • CPU Socket FM2
  • CPU Socket FM1
  • Fan Speed 650-1800 RPM (PWM) ± 10%
  • Fan Noise Level 8 - 27 dBA
  • Dimensions (L x W x H) 120 x 80 x 158 mm / 4.7 x 3.1 x 6.2 inch
  • Fan Air Pressure 2.52 mmH2O
  • Fan Airflow 61 CFM (Max)
  • Product Number RR-212A-18PC-A1
