Hyper 212 Pro image number 0
Hyper 212 Pro image number 1
Hyper 212 Pro image number 2
Hyper 212 Pro image number 3
Hyper 212 Pro image number 4
Hyper 212 Pro
Hyper 212 Pro
Hyper 212 Pro
Hyper 212 Pro
Hyper 212 Pro
Cool Efficiency Redefined
Hyper 212 Pro
Superconductive Composite Heat Pipes
Higher TDP
Optimized Tower Cooler Design
100% RAM Clearance
SickleFlow Edge 120 Fans
Cooler Master’s masterclass HYPER 212 series makes a triumphant return with the HYPER 212 PRO, a new take on a classic design featuring our in-house design heat pipes.
The optimized design ensures better airflow and heat dissipation, which results in improved cooling efficiency and overall system performance.
By using various evaporator and condensor wick structures, our SCHPs greaty enhance performace for improved heat dissipation
All-new Top Cover Design
A sleek and modern top cover enhances the overall look of your build, giving it a stylish and professional appearance.
A SickleFlow Edge fan combines exceptional heat dissipation performance with a visually striking design.
Easy fan mount
Simplifies the installation process, allowing users to set up the cooler quickly and efficiently.
  • Product Number RR-212S-25PZ-R1
  • Exterior Color Black
  • Dimensions (L x W x H) 125 x 74 x 152 mm / 4.9 x 2.9 x 5.9 inch
  • Fan Quantity 1 PC
  • Fan Airflow 70.7 CFM (Max)
  • Fan Pressure 3.61 mmH₂O (Max)
  • Fan MTTF >160,000 Hours
  • Fan Noise Level 32.8 dBA (Max)
  • Fan Rated Current 0.2A
  • Fan Safety Current 0.3A
  • Fan Power Consumption 2.4W
  • Cooler Type Air Cooler
  • Series Hyper
  • Heatpipes 4
