Hyper 212 Plus (Fan Bracket Version)
CPU SupportCore™ i7 Extreme
Cooler TypeAir Cooler
Fan MTTF40,000 Hours
LegacyCooling
Fan Bearing TypeLong Life Sleeve Bearing
Fan Power Connector4-Pin (PWM)
CPU SupportCore™ i7
CPU SupportCore™ i5
Note*The supplied accessories may differ by country or area. Please check with your local distributor for further details.
Weight626g
CPU SupportCore™ i3
CPU SupportCore™2 Extreme
Fan Speed600-2000 RPM (PWM) ± 10%
SeriesHyper
CPU SupportCore™2 Quad
CPU SupportCore™2 Duo
CPU SocketLGA1366
CPU SupportPentium
CPU SupportCeleron
CPU SocketLGA1156
CPU SocketLGA1155
Heat Sink Material4 Heat Pipes
CPU SupportAMD FX-Series
CPU SupportAMD A-Series
CPU SocketLGA1151
CPU SocketLGA1150
CPU SupportAMD Phenom™ II X4
Fan Airflow21.2 - 76.8 CFM
Fan Air Pressure0.40 - 3.90 mmH2O
CPU SupportAMD Phenom™ II X3
CPU SocketLGA775
Heat Sink MaterialAluminum Fins
CPU SupportAMD Phenom™ II X2
CPU SupportAMD Phenom™ X4
Dimensions (L x W x H)120 x 79.7 x 158.5 mm
CPU SupportAMD Phenom™ X3
CPU SupportAMD Athlon™ II X4
CPU SocketAM3+
CPU SocketAM3
CPU SupportAMD Athlon™ II X3
CPU SupportAMD Athlon™ II X2
CPU SocketAM2+
CPU SocketAM2
CPU SupportAMD Athlon™ X2
Fan Noise Level13 - 32 dBA
EAN code4719512015537
UPC code884102005077
CPU SocketFM2+
Product NumberRR-B10-212P-G1
CPU SocketFM2
CPU SupportAMD Sempron™
CPU SocketFM1
