Hyper 212 LED Turbo image number 0
Hyper 212 LED Turbo image number 1
Hyper 212 LED Turbo image number 2
Hyper 212 LED Turbo image number 3
Hyper 212 LED Turbo image number 4
Hyper 212 LED Turbo image number 5
Hyper 212 LED Turbo image number 6
Hyper 212 LED Turbo image number 7
Hyper 212 LED Turbo image number 8
Hyper 212 LED Turbo image number 9
Hyper 212 LED Turbo image number 10
Hyper 212 LED Turbo image number 11
Hyper 212 LED Turbo image number 12
Hyper 212 LED Turbo image number 13
Hyper 212 LED Turbo image number 14
Hyper 212 LED Turbo image number 15
Hyper 212 LED Turbo image number 16
Hyper 212 LED Turbo image number 17
Hyper 212 LED Turbo image number 18
Hyper 212 LED Turbo image number 19
Hyper 212 LED Turbo
Hyper 212 LED Turbo
Hyper 212 LED Turbo
Hyper 212 LED Turbo
Hyper 212 LED Turbo
Hyper 212 LED Turbo
Hyper 212 LED Turbo
Hyper 212 LED Turbo
Hyper 212 LED Turbo
Hyper 212 LED Turbo
Hyper 212 LED Turbo
Hyper 212 LED Turbo
Hyper 212 LED Turbo
Hyper 212 LED Turbo
Hyper 212 LED Turbo
Hyper 212 LED Turbo
Hyper 212 LED Turbo
Hyper 212 LED Turbo
Hyper 212 LED Turbo
Hyper 212 LED Turbo
Hyper 212 LED Turbo
Hyper 212 LED Turbo provides the best balance between airflow and static pressure to take the heat away...
  • Heat Pipe Dimensions Ø6mm
  • Cooler Type Air Cooler
  • Fan MTTF 40,000 Hours
  • Heatpipes 4
  • Series Hyper
  • Heat Sink Dimensions (L x W x H) 120 x 60 x 160 mm / 4.7 x 2.4 x 6.3 inch
  • Fan Air Pressure 1.7 mmH2O ± 10%
  • Heat Sink Weight 468g
  • Dimensions (L x W x H) 120 x 108 x 163 mm / 4.7 x 4.3 x 6.4 inch
  • Heat Sink Material 4 Heat Pipes
  • Fan Noise Level 9 - 31 dBA
  • Product Number RR-212TK-16PR-R1 (Black Top Cover)
  • Product Number RR-212TR-16PR-R1 (Red Top Cover)
  • Heat Sink Material Direct Contact
  • Note N/A
  • Fan Power Consumption 2.28W
  • Fan Rated Current 0.19A
  • CPU Socket LGA2066, LGA2011-V3, LGA2011, LGA1366, LGA1200, LGA1156, LGA1155, LGA1151, LGA1150, LGA775, AM4, AM3+, AM3, AM2+, FM2+, FM2, FM1
  • Fan Airflow 66.3 CFM ± 10%
  • Fan Speed 600-1600 RPM (PWM) ± 10%
