Hyper 212 Flow Series image number 0
Hyper 212 Flow Series image number 1
Hyper 212 Flow Series image number 2
Hyper 212 Flow Series image number 3
Hyper 212 Flow Series image number 4
Hyper 212 Flow Series image number 5
Hyper 212 Flow Series image number 6
Hyper 212 Flow Series image number 7
Hyper 212 Flow Series image number 8
Hyper 212 Flow Series image number 9
Pure Style, Powerful Flow.
• Direct Contact Technology
• Unified Installation Bracket
• High-Performance Airflow
• Minimalist Aesthetic
PURE STYLE, POWERFUL FLOW.
The Hyper 212 Flow is a high-performance cooling solution featuring four heat pipes with Direct Contact Technology for optimized thermal dissipation. Its minimalist two-piece cover provides a sleek, distinctive aesthetic. Featuring a unified bracket for simplified installation across platforms, it delivers powerful airflow and exceptional reliability.
DIRECT CONTACT TECHNOLOGY
Four optimized heat pipes use Direct Contact Technology to maximize heat dissipation directly from the CPU, ensuring efficient thermal performance for high-performance workloads.
UNIFIED INSTALLATION BRACKET
The new mounting bracket simplifies setup by using a single, universal solution for both Intel and AMD sockets, making installation faster and more intuitive for every builder.
HIGH-PERFORMANCE AIRFLOW
Delivering 68.85 CFM of airflow and 1.87 mmH₂O of pressure, the fan provides consistent cooling for demanding CPUs even under heavy thermal loads.
MINIMALIST AESTHETIC
Featuring a sleek two-piece upper cover, the design provides a simple yet distinctive visual appearance that delivers a clean, professional look for any modern build.
RELIABILITY AND WARRANTY
Backed by a 3-year warranty, this cooling solution is built for long-term durability and dependable performance, ensuring your system stays cool for years to come.
  • Product Name Hyper 212 Flow
  • Model Number MAX-T4PN-217PK-R1
  • Exterior Color Black
  • CPU Socket Intel® LGA 1700 / 1200 / 1151 / 1150 / 1155 / 1156
  • CPU Socket AMD® AM5 / AM4
  • Dimensions 125 x 91 x 154 mm (4.9 x 3.6 x 6.1 inch)
  • Fan Dimensions (L x H x W) 120 x 120 x 25.4mm (4.7 x 4.7 x 1 inch)
  • Fan Profiles None
  • Fan Quantity (pcs) 1 PCS
  • Fan Speed 650~1750 RPM ± 10%
  • Fan Air Flow (Max) 127.75 m³/h(75.19 CFM)
  • Fan Air Pressure (Max) 1.83 mmH2O
  • Fan MTTF >160,000 hours
  • Fan Noise Level (Max) 32.2dB (A)
  • Fan Bearing Hydraulic bearing
  • Fan Connector 4-Pin PWM
  • Fan Rated Current 0.21A
  • Fan Safety Current 0.37 A
  • Fan Power Consumption 2.64 W
  • Warranty 3 years
