Hyper 212 V2 CPU Air Cooler image number 0
Hyper 212 V2 CPU Air Cooler image number 1
Hyper 212 V2 CPU Air Cooler image number 2
Hyper 212 V2 CPU Air Cooler image number 3
Hyper 212 V2 CPU Air Cooler image number 4
Hyper 212 V2 CPU Air Cooler image number 5
Hyper 212 V2 CPU Air Cooler image number 6
Hyper 212 V2 CPU Air Cooler image number 7
Hyper 212 V2 CPU Air Cooler image number 8
Hyper 212 V2 CPU Air Cooler image number 9
Hyper 212 V2 CPU Air Cooler image number 10
Cooler Master has revived the legendary Hyper 212 EVO with major improvements. Upgraded with an asymmetrical heat pipe design...
  • Cooler Type Air Cooler
  • Fan Quantity 240: 2 PCS | 360: 3PCS
  • Legacy Cooling
  • Exterior Color Black
  • Exterior Color Silver
  • Fan MTTF 160,000 Hours
  • Heatpipes 4
  • Fan Safety Current 0.37A
  • Series Hyper
  • Heat Sink Material 4 Heat Pipes
  • Heat Sink Material Direct Contact
  • CPU Socket LGA1200, LGA2066, LGA2011-V3, LGA2011, LGA1151, LGA1150, LGA1155, LGA1156, LGA1366, LGA775, AM4, AM3+, AM3, AM2+, AM2, FM2+, FM2, FM1
  • Fan Power Consumption 1.8W
  • Fan Rated Current 0.15A
  • Fan Noise Level 8 - 27 dBA
  • Dimensions (L x W x H) 120 x 80 x 154 mm / 4.7 x 3.1 x 6.1 inch
  • Fan Speed 650-1800 RPM (PWM) ± 5%
  • Fan Air Pressure 2.5 mmH2O (Max)
  • Fan Airflow 62 CFM (MAX)
  • Product Number RR-2V2E-18PK-R1
