Hyper 101 image number 0
Hyper 101 image number 1
Hyper 101 image number 2
Hyper 101 image number 3
Hyper 101 image number 4
Hyper 101
Hyper 101
Hyper 101
Hyper 101
Hyper 101
Hyper 101
Hyper 101
  • Cooler Type Air Cooler
  • Fan Power Connector 3-Pin
  • Legacy Cooling
  • Fan Bearing Type Long Life Sleeve Bearing
  • Fan Life Expectancy 40,000 Hours
  • Fan Dimensions (L x W x H) 80 x 80 x 25 mm / 3.1 x 3.1 x 1.0 inch
  • Series Hyper
  • CPU Socket LGA1156
  • CPU Socket LGA1155
  • CPU Socket LGA1151
  • CPU Socket LGA1150
  • Heat Sink Material 2 Heat Pipes
  • CPU Socket LGA775
  • CPU Socket AM4
  • CPU Socket AM3+
  • CPU Socket AM3
  • Fan Noise Level 13 - 28 dBA (PWM version)
  • CPU Socket AM2
  • CPU Socket FM2+
  • Fan Airflow 30 CFM (Fix speed version)
  • CPU Socket FM2
  • CPU Socket FM1
  • CPU Socket 940
  • CPU Socket 939
  • Weight Intel version: 315g
  • Weight AMD version: 304g
  • Fan Noise Level 22 dBA (Fix speed version)
  • Fan Air Pressure 2.28 mmH2O (Fix speed version)
  • Fan Air Pressure 0.3 - 4.23 mmH2O (PWM version)
  • Fan Speed 2200 RPM (Fix speed version)
  • Fan Speed 800-3000 RPM (PWM) ­± 10%
  • Dimensions (L x W x H) 83.5 x 68 x 117 mm
  • Fan Airflow 10.9 - 40.8 CFM (PWM version)
  • Product Number RR-H101
