Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 0
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 1
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 2
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 3
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 4
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 5
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 6
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 7
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 8
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 9
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 10
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 11
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 12
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 13
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 14
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 15
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 16
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 17
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 18
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 19
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 20
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 21
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 22
The Best of Both Worlds
Hybrid 1 Ergo gaming chair 30th anniversary edition combines the benefits of comfort-driven office chairs with support-based racing seats.
In a world of comfort and expression, the 30th Anniversary Edition Hybrid 1 is a special version of the current Hybrid 1. Hybrid 1 combines the benefits of comfort-driven office chairs with support-based racing seats that allow ergonomic customization to a user’s preference for maximum airflow during longer sessions. 30th Anniversary edition is styled particularly on the front and back end of the headrest, along with a rainbow-colored pulley.
Professional and Clean
A professional office design melded together with a gaming racing chair, Hybrid 1's premium materials and clean aesthetic is perfect for blending into any type of environment such as an office environment or your personal gaming setup back at home.
MUSCLEFLEX® MESH
FULLY-ADJUSTABLE LUMBAR SUPPORT
ADJUSTABLE NECK SUPPORT
3D ARMREST
High-Density Molded Foam
Hybrid 1 is designed to offer an all-day comfortable seating experience, built with high-density molded foam that provides extra cushioning for the best sitting experience. The premium plush materials ensure you'll remain comfortable even after extended periods of sitting.
Advanced Air Ventilation
Using our exclusive cold molded-foam technology in the seat base of the Hybrid 1, air ventilation is vastly improved leading to reduced heat buildup. The premium molded foam serves as an extremely comfortable base, conforming to your body and allowing you to sit on the Hybrid 1 for even the longest of work and play days.
Premium Steel Frame and Aluminum Base Construction
Comprised with a rock-steady steel frame in combination with a premium aluminum base, the Hybrid 1 is built with high-quality materials that is not only reliable, but will last for years on end.
75mm SILENT CASTERS
Large premium caster wheels roll exceptionally well on all surfaces while producing less noise than traditional casters.
PRECISION CLASS 4 GAS LIFT
With a premium precision class 4 gas lift, Hybrid 1's height adjustments are accurate and reliable every time.
  • Product Number CMI-GCHYB1-BK30TH
  • Color 30th Anniversary Edition
  • Total Height Range 124-134 cm / 48.8"-52.8"
  • Backrest Height 78 cm / 30.7"
  • Backrest Width 54 cm / 21.3"
  • Armrest to Armrest 75 cm / 29.5"
  • Seat Width (including sides) 61 cm / 24.0"
  • Sitting Area 61 cm / 24.0"
  • Seat Depth 54 cm / 21.3"
  • Diameter of Base 68 cm / 26.8"
  • Steel Plate Thickness 1.5 mm
  • Armrest Adjustability 29-36 cm / 11.4"-14.2"
  • Floor to Seat Top 48-58 cm / 18.9"-22.8"
  • Height Adjustability 10 cm / 3.9"
  • Recline 90-180 degree
  • Armrest 3D
  • Headrest Integrated headrest (up/down)
  • Lumbar Support Built-in 2D lumbar support (up/down, forward/backward)
  • Outer Material Backrest: MuscleFlex® Mesh, Seatbase: Perforated PU
  • Inner Material High density cold-molded foam
  • Frame Material Steel
  • Base (leg) Aluminum
  • Caster 75 mm / 3.0"
  • Gas Lift Class 4
  • Net Weight 26.3 kg
  • Gross Weight 31.2 kg
  • Max. Weight Load 150 kg / 330 lbs
  • Product Gaming Chair
  • Chair Type Hybrid Series
