HAF XB (Windowed Top Panel Version) image number 0
HAF XB (Windowed Top Panel Version) image number 1
HAF XB (Windowed Top Panel Version) image number 2
HAF XB (Windowed Top Panel Version) image number 3
HAF XB (Windowed Top Panel Version) image number 4
HAF XB (Windowed Top Panel Version) image number 5
HAF XB (Windowed Top Panel Version) image number 6
HAF XB (Windowed Top Panel Version) image number 7
HAF XB (Windowed Top Panel Version) image number 8
The Cooler Master HAF XB takes the famous High Air Flow series to a revolutionary new form factor with extreme cooling performance.
  • Maximum Compatibility - Water Cooling Support 240mm Radiator x 1 (Front)
  • Maximum Compatibility - Water Cooling Support 120mm Radiator x 1 (Rear)
  • Legacy Cases
  • I/O Panel 2x USB 3.0
  • 5.25" Drive Bays 2
  • Motherboard Support ATX
  • Expansion Slots 7
  • Materials Steel body
  • Materials Plastic bezel
  • Power Supply Support ATX PS2 (Support Max. of the PSU in 180mm Length)
  • Cooling System - Rear 120mm fan x 1 (optional), and 80mm fan x 2 (optional)
  • Maximum Compatibility - CPU Cooler Height 180mm / 7.1 inch
  • Maximum Compatibility - VGA Card Length 334mm / 13.1 inch
  • Weight 8.2 kg / 18.1 lb
  • 3.5" Drive Bays 2 (from X-Dock)
  • Cooling System - Front 120mm fan x 2, 1800 RPM, 21 dBA (or 140mm fan x 2)
  • 2.5" Drive Bays 6 (2 from X-Dock)
  • Materials Front Mesh
  • Dimensions (L x W x H) 442 x 330 x 423 mm / 17.4 x 13 x 16.7 inch
  • Model Number RC-902XB-KWN1
