HAF X
HAF X
SizeFull Tower
MaterialsSteel
Cooling System - Front230 x 30mm Red LED Fan x 1 / 700 RPM / 19 dBA
Cooling System - Side230 x 30mm Standard Fan x 1 / 700 RPM / 19 dBA (Supports 120mm Fan x 4)
Cooling System - Rear140 x 25mm Fan x 1, 1200 RPM, 17 dBA (Supports 140mm Fan)
Cooling System - VGA Card Fan Duct1x 120x25mm or 120x38mm Fan (Optional)
Cooling System - VGA card holder1x 80x15mm Fan (Optional)
Cooling System - Top200 x 30mm fan x 2 (one is optional)
LegacyCases
I/O Panel2x USB 3.0
Power Supply SupportATX
Peripheral 4 Pin Connectors9
2.5" Drive Bays2 (from 5.25" drive bays)
Motherboard SupportXL-ATX
SATA Connectors9
Power Supply SupportATX PS2
I/O Panel2x USB 2.0
Motherboard SupportE-ATX
Motherboard SupportATX
Color(s)Midnight Black
Dimensions (L x W x H)230 x 599 x 550 mm / 9.1 x 23.6 x 21.7 inch
5.25" Drive Bays6 (2 from X-Dock)
MaterialsPolymer
Motherboard SupportMicro ATX
SeriesHAF Series
MaterialsMesh
3.5" Drive Bays5 (hidden) (supports 2-in-1 2.5" and 1.8" SSD)
I/O Panel1x e-SATA
I/O Panel1x IEEE 1394a
I/O Panel1x Mic
I/O Panel1x Audio (supports HD audio)
Maximum Compatibility - VGA Card Length342mm / 13.5 inch
Maximum Compatibility - CPU Cooler Height190mm / 7.5 inch
Weight14.35 kg / 31.6 lbs
Model NumberRC-942-KKN1
Confirm your Country
It looks like you're in
