HAF 932 Advanced image number 0
HAF 932 Advanced image number 1
HAF 932 Advanced image number 2
HAF 932 Advanced image number 3
HAF 932 Advanced image number 4
HAF 932 Advanced image number 5
HAF 932 Advanced image number 6
HAF 932 Advanced image number 7
HAF 932 Advanced
HAF 932 Advanced
HAF 932 Advanced
HAF 932 Advanced
HAF 932 Advanced
HAF 932 Advanced
HAF 932 Advanced
HAF 932 Advanced
HAF 932 Advanced
HAF 932 Advanced
  • Size Full Tower
  • Cooling System - Front 230 x 30mm Red LED Fan x 1 / 700 RPM / 19 dBA
  • Cooling System - Side 230 x 30mm Standard Fan x 1 / 700 RPM / 19 dBA (Supports 120mm Fan x 4)
  • Cooling System - Top 230 x 30mm Fan x 1 / 700 RPM / 19 dBA (Supports 120mm Fan x 3 / 120mm Fan x 1 + 230 x 30mm Fan x 1)
  • Cooling System - Rear 140 x 25mm Fan x 1, 1200 RPM, 17 dBA (Supports 140mm Fan)
  • Legacy Cases
  • Materials Plastic
  • I/O Panel 2x USB 3.0
  • Color(s) Black
  • Power Supply Support EPS 12V (Optional)
  • 5.25" Drive Bays 5 (without the use of exposed 3.5 inch drive bay)
  • Motherboard Support E-ATX
  • Dimensions (L x W x H) 243 x 560 x 564mm / 9.6 x 22.0 x 22.2 inch
  • Motherboard Support ATX
  • Expansion Slots 7
  • Materials SECC
  • 3.5" Drive Bays 5 Hidden
  • I/O Panel 4x USB 2.0
  • Series HAF Series
  • 3.5" Drive Bays 1 Exposed (converted from one 5.25" drive bay)
  • 2.5" Drive Bays 4 (converted from two 3.5" drive bay)
  • Maximum Compatibility - VGA Card Length 320.7mm
  • I/O Panel 1x e-SATA
  • I/O Panel 1x IEEE 1394a
  • Maximum Compatibility - CPU Cooler Height 172.1mm
  • I/O Panel 1x Mic
  • Weight 13.4 kg / 29.5 lbs
  • Model Number RC-932-KKN5-GP
