HAF 922
HAF 922
MaterialsSteel
Optional ComponentTransparent Acrylic Side Panel
LegacyCases
Color(s)Black
SizeMid Tower
Power Supply SupportATX PS2
Cooling System - Bottom1x 120/140mm Fan (Optional)
Power Supply SupportEPS 12V (Optional)
I/O Panel2x USB 2.0
Cooling System - Top120/140mm fan x 1 (optional)
Expansion Slots7+1
Cooling System - Rear120mm fan x 1 (installed, 1200 RPM, 17 dBA)
Motherboard SupportATX
Motherboard SupportMicro ATX
3.5" Drive Bays5 Hidden
3.5" Drive Bays1 Exposed (converted from one 5.25" drive bay)
SeriesHAF Series
Cooling System - Side200 mm fan x 1 (optional) (can be swap for 120 mm fan x 2)
Gross Weight10.9 kg / 24.0 pounds
Cooling System - Top200mm black fan x 1 (optional; can be swapped for two 120mm fans)
Cooling System - Front200mm red LED fan x 1, 700RPM,19dBA (can be swapped for two 120mm fans)
MaterialsMesh and Plastic
I/O Panel1x Mic
I/O Panel1x eSATA
I/O Panel1x Audio (supports HD audio)
5.25" Drive Bays5 Exposed (one could convert to 3.5" drive bay)
Net Weight8.7 kg / 19.2 pounds
Dimensions (L x W x H)Main: 253 x 502 x 563 mm / 10.0 x 19.7 x 22.2 inches
Dimensions (L x W x H)Box: 285 x 550 x 605 mm / 11.2 x 21.7 x 23.8 inches
Model NumberRC-922M
