HAF 912 Combat (for APAC only)
MaterialsSteel
I/O Panel1x USB 3.0
SizeMid Tower
LegacyCases
Cooling System - Top120mm fan x 2 (optional)
I/O Panel1x USB 2.0
Power Supply SupportATX PS2
Cooling System - Side120/140mm fan x 1 (optional)
Cooling System - Rear120mm fan x 1 (installed, 1200 RPM, 17 dBA)
Maximum Compatibility - VGA Card Length270mm / 10.6 inch (with HDD cage)
Power Supply SupportEPS 12V (Optional)
Expansion Slots7+1
Color(s)Midnight Black
MaterialsPolymer
MaterialsMesh
SeriesHAF Series
3.5" Drive Bays1 Exposed (converted from one 5.25" drive bay)
Cooling System - Topor 200mm fan x 1 (optional)
Cooling System - Front120mm fan x 2 (one is optional; can be swapped for one 200mm fan)
Maximum Compatibility - CPU Cooler Height175mm / 6.9 inch
I/O Panel1x Mic
I/O Panel1x Audio (supports HD audio)
5.25" Drive Bays4 (exposed; one is converted to 3.5” bay)
Maximum Compatibility - VGA Card Length390mm / 15.4 inch (w/o the 1st HDD cage)
Net Weight8.07 kg / 17.8 lb
2.5" Drive Bays4 (hidden; two are converted from 3.5” bays)
Dimensions (L x W x H)230 x 480 x 496 mm / 9.1 x 18.9 x 19.5 inch
Model NumberRC-912-KKN2
