HAF 700 image number 0
HAF 700 image number 1
HAF 700 image number 2
HAF 700 image number 3
HAF 700 image number 4
HAF 700 image number 5
HAF 700 image number 6
HAF 700 image number 7
HAF 700 image number 8
HAF 700 image number 9
HAF 700 image number 10
HAF 700 image number 11
HAF 700 image number 12
HAF 700 image number 13
HAF 700 image number 14
HAF 700 image number 15
HAF 700 image number 16
HAF 700 image number 17
HAF 700 image number 18
HAF 700 image number 19
HAF 700 image number 20
HAF 700 image number 21
HAF 700 image number 22
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
The Berserker
HAF 700
• Unparalleled Hardware & Cooling Capabilities
• Mammoth Water Cooling Support
• Exclusive Tool-Less Technology
• ARGB Gen2 ready with MasterPlus+ integration
IN SPIRIT OF COOLER MASTER'S HAF LEGACY
HAF 700 embodies the spirit of HAF's performance oriented design, boasting attention to mechanical detail.
Our Achievements
14 AWARDS
No Limits
Hardware & Connectivity
No Limits
The HAF 700 is capable of housing up to SSI-EEB motherboards (E-ATX), as well as any sized graphics cards in BOTH horizontal and vertical orientations.
Rich Connectivity
Rich Connectivity
The front I/O is designed to maximize the front connectivity for most high end motherboards, featuring four USB Gen 3.1 Type A ports, a USB Gen 3.2 Type C, a 4 pin audio/mic headset jack as well as a dedicated mic jack.
Custom Cooling
6x
MAMMOTH RADIATOR SUPPORT
Fans
Exclusive SickleFlow fans
HAF 700 comes with dual exclusive 200mm Sickleflow ARGB PWM "Performance Edition" fans tailored to strike a balance between performance potential and noise levels
Unrestricted Front Panel Intake
HAF 700 sports a fully meshed front panel, specifically designed to allow for maximum air intake. With the front panel structurally reinforced to prevent resonation caused by fan vibrations, systems can run smoothly at minimal noise levels.
Effortless Management
12x
INTEGRATED HUB
Installation
ADVANCED MOUNTING OPTIONS
The unique removable top panel design allows you to effortlessly install, reach and maintain cooling components such as fans and radiators even in builds with complex custom cooling systems. This, coupled with the rotatable radiator/fan bracket included out of the box allows for an unparalleled building experience.
Software
MASTERPLUS+ SOFTWARE INTEGRATION
Design
TOOL-LESS INSTALLATION
Design
MULTI CHAMBER LAYOUT
HAF 700's structure segregates non heat sensitive components so heat dissipation can be targeted towards heat sensitive components at an overall higher efficiency.
  • Model Number HAF 700: H700-IGNN-S00, HAF 700 WHITE: H700-WGNN-S00
  • Exterior Color Titanium Grey, White
  • Materials - Exterior Steel, Plastic
  • Materials - Left Side Panel Tempered Glass, Steel, Plastic
  • Dimensions (L x W x H) 556 x 279 x 540 mm (Body Size)
  • Dimensions (L x W x H) 666 x 291 x 626 mm (incl. Protrusions)
  • Motherboard Support Mini-ITX, Micro-ATX, ATX, E-ATX, SSI-CEB, SSI-EEB
  • Expansion Slots 8
  • 2.5" / 3.5" Drive Bays (Combo) 9 (4*HDD bracket, 5*Screw+Rubber)
  • I/O Panel - USB Ports 1x USB 3.2 Gen 2 Type C, 4x USB 3.2 Gen 1 (3.0)
  • I/O Panel - Audio In / Out 1x 3.5mm 4 Poles Audio Jack, 1x 3.5mm Mic Jack
  • Pre-installed Fans - Front 2x SickleFlow 200 ARGB PWM
  • Pre-installed Fans - Rear 2x SickleFlow 120 ARGB PWM
  • Pre-installed Fans - Bottom 1x SickleFlow 120 ARGB PWM
  • Fan Support - Top 2x 200mm, 3x 140mm, 6x 120mm (Remove 480mm bracket)
  • Fan Support - Front 2x 200mm
  • Fan Support - Rear 2x 120mm
  • Fan Support - Bottom 3x 120/140mm
  • Fan Support - Side 4x 120mm / 3x 140mm
  • Radiator Support - Top Up to 2x 360mm / 1x 420mm
  • Radiator Support - Rear Up to 240mm
  • Radiator Support - Bottom Up to 420/360mm
  • Radiator Support - Side Up to 480/420/360mm
  • Clearance - CPU Cooler 166mm / 6.53"
  • Clearance - PSU 200mm / 7.87"
  • Clearance - GFX 490mm / 19.29"
  • Cable Routing - Behind Motherboard Tray 90-101mm
  • Included Accessories 1x Rotatable Radiator Bracket, 1x LED Controller A1 (ARGB Gen2), 1x ARGB/PWM Hub
  • Dust Filters Bottom, Right Side
  • Size Full Tower
  • Series HAF Series
  • Note * For regular 30mm thick radiators, for thicker please reference compatibility sheet.
