GX III Gold 750 ATX 3.1 image number 0
GX III Gold 750 ATX 3.1 image number 1
GX III Gold 750 ATX 3.1 image number 2
GX III Gold 750 ATX 3.1 image number 3
GX III Gold 750 ATX 3.1 image number 4
GX III Gold 750 ATX 3.1 image number 5
GX III Gold 750 ATX 3.1 image number 6
Strength in Elegance
• ATX 3.1 support & a 90-degree 12V-2X6 cable
• Titanium efficiency at light loads
• Fully modular cabling
• 10-year warranty
Innovative, Streamlined Design
ATX 3.1 Support & a Durable 90-degree 12V-2x6 Cable
Includes ATX 3.1 support and a 90-degree 12V-2X6 PCle 5.1 connector featuring higher electrical durability, improved safety, and capable of bringing up to 600W to your GPU.
Exceptional Efficiency
This 80 Plus Gold certified unit can achieve Titanium level efficiency at light loads in a 115V test.
Optimized Thermal Performance
An anodic-coated heat sink keeps average temperatures 5℃ lower than a traditional heat sink for enhanced durability and a prolonged life span.
Fully Modular Cabling
Silent and smart performance
Zero-RPM default mode below 40% loads.
PSU Calculator
  • Model MPX-7503-AFAG
  • Input Current 10-5A
  • Fan Size 135mm
  • Fan Bearing HDB
  • Fan Speed 1900 RPM
  • 80 PLUS Rating 80 PLUS Gold
  • Hold Up Time ≥ 16ms
  • EPS 4+4 Pin Connectors 1
  • EPS 8 Pin Connector 1
  • SATA Connectors 8
  • PCI-e 6+2 Pin Connectors 3
  • 12V-2x6 Connectors 1
  • Series GX Series
  • 80 Plus Efficiency Gold
  • Category Above 750W
  • Watts 750W
