GX Gold 750 ATX 3.1 image number 0
GX Gold 750 ATX 3.1 image number 1
GX Gold 750 ATX 3.1 image number 2
GX Gold 750 ATX 3.1 image number 3
GX Gold 750 ATX 3.1
GX Gold 750 ATX 3.1
GX Gold 750 ATX 3.1
GX Gold 750 ATX 3.1
Level Up Your Power
GX Gold 750 ATX 3.1
ATX 3.1 support
A 90-degree 12V-2x6 adapter cable
High temperature resilience​​
Fully modular cabling
5-year warranty
High Temperature Resilience​
A 50°C operating temperature and high quality Japanese capacitors allow for pushing your machine to the limits.​
Certified Efficiency
The GX Gold ATX 3.1 is certified to achieve more than 90% efficiency at typical loads.​​
Fully Modular Cabling
Three 8-pin Connectors
Up to 600W of power is split between three 8-pin connectors, providing enhanced safety.
  • Model MPE-7501-AFAAG-3E**
  • Input Current 10-5A
  • Fan Bearing HDB
  • 80 PLUS Rating 80 PLUS Gold
  • Hold Up Time ≥ 16ms
  • Regulatory TUV, CE, CCC, EAC, RCM, cTUVus, FCC, BSMI, BIS, UKCA
  • EPS 4+4 Pin Connectors 1
  • EPS 8 Pin Connector 1
  • SATA Connectors 12
  • PCI-e 6+2 Pin Connectors 4
  • 12V-2x6 Connectors 1 (1 to 3)
  • Category Above 750W
  • Series GX Series
  • 80 Plus Efficiency Gold
  • Watts 750W
