GM34-CW Gaming Monitor image number 0
GM34-CW Gaming Monitor image number 1
GM34-CW Gaming Monitor image number 2
GM34-CW Gaming Monitor image number 3
GM34-CW Gaming Monitor image number 4
GM34-CW Gaming Monitor image number 5
GM34-CW Gaming Monitor image number 6
GM34-CW Gaming Monitor image number 7
GM34-CW Gaming Monitor image number 8
GM34-CW Gaming Monitor image number 9
GM34-CW Gaming Monitor image number 10
GM34-CW Gaming Monitor image number 11
The Power to Bend Reality
Cooler Master GM34-CW is designed for gamers who are not willing to compromise their experience in both the gaming competency and the beauty of game.
  • Curve 1500R
  • Ratio 21:9
  • Screen Size 34"
  • Panel VA w/ Quantum Dot
  • Resolution UWQHD 3440x1440
  • Brightness 400 nits
  • Color Gamut 95% DCI-P3 (125% sRGB) (±3)
  • I/O - DP 2
  • I/O - HDMI 2
  • I/O - Earphone Out 1
  • FreeSync FreeSync 2 Compatible
  • PIP/PBP (Screen Split) Yes
  • DisplayHDR400 Compatible
  • HDR10 Support (w/ FreeSync) Yes
  • Anti-flicker Yes
  • Response Time 1ms (MPRT)
  • Mode Switch Standard
  • Lighting Purple (Steady & Blinking modes)
  • VESA 75x75 mm
  • Height Adjustment 0-100 mm
  • Swivel Adjustment -45°~+45°
  • Tilt Adjustment -5°~+15°
  • I/O - DP 1.4 Cable 1
  • I/O - Speaker 2 (4Ω/3W)
  • Contrast Ratio 3000:1
  • Screen Type Curved Series
  • Power Consumption 39W (Typ.)**
  • Note * All may vary by models and region. Specifications and features are subject to change without notice.
  • Note ** Measure a screen brightness of 200nits without audio/USB/Card reader connection.
  • Monitor Series GM Series
  • Mode Switch Graphic
  • Mode Switch Movie
  • Product Gaming Monitor
  • Refresh Rate 144 Hz (Samsung)
  • Refresh Rate 144 Hz (Overclock to 165Hz) (AUO)
  • Mode Switch Game
  • Product Number CMI-GM34-CW (Samsung) EOL
  • Net Weight 7.99 kg
  • Gross Weight 11.95 kg
  • Product Number CMI-GM34-CW2 (AUO)
