GM27-FQS ARGB 30th Anniversary Edition image number 0
GM27-FQS ARGB 30th Anniversary Edition image number 1
GM27-FQS ARGB 30th Anniversary Edition image number 2
GM27-FQS ARGB 30th Anniversary Edition image number 3
GM27-FQS ARGB 30th Anniversary Edition image number 4
GM27-FQS ARGB 30th Anniversary Edition image number 5
GM27-FQS ARGB 30th Anniversary Edition image number 6
GM27-FQS ARGB 30th Anniversary Edition image number 7
GM27-FQS ARGB 30th Anniversary Edition image number 8
GM27-FQS ARGB 30th Anniversary Edition image number 9
GM27-FQS ARGB 30th Anniversary Edition image number 10
GM27-FQS ARGB 30th Anniversary Edition image number 11
GM27-FQS ARGB 30th Anniversary Edition image number 12
GM27-FQS ARGB 30th Anniversary Edition image number 13
GM27-FQS ARGB 30th Anniversary Edition image number 14
Bring Gaming to Life
The 30th Anniversary Edition of the GM27-FQS ARGB Gaming Monitor is a special limited edition product that celebrates the history of Cooler Master.
  • Response Time 1ms (MPRT)
  • Mode Switch Standard
  • VESA 75x75 mm
  • I/O - USB 3.0 Type A 2
  • I/O - USB 3.0 Type B 1
  • I/O - USB Type C 1
  • I/O - HDMI 2.0 2
  • Pivot Adjustment Horizontal / Vertical
  • HDR 10
  • Note ** Measure a screen brightness of 200nits without audio/USB/Card reader connection.
  • Monitor Series GM Series
  • VRR Technology FreeSync Range: Yes
  • Tilt Adjustment -5°~+20°
  • Ratio 16:9
  • Screen Type Flat Series
  • Mode Switch Graphic
  • Brightness 300 nits (Typical)
  • I/O - DP 1
  • Height Adjustment 0-110 mm
  • Swivel Adjustment -15°~+15°
  • Mode Switch Movie
  • Resolution 2K QHD 2560x1440
  • Screen Size 27"
  • Product Gaming Monitor
  • Contrast Ratio 1000:1
  • VRR Technology G-Sync Range: Yes
  • Power Consumption 30W (Typ.)**
  • Color Gamut DCI-P3 90%
  • Lighting ARGB Stand
  • VRR Technology FreeSync Premium
  • Panel AHVA 8bit (Ultra Speed IPS)
  • Refresh Rate 165 Hz
  • Mode Switch Game
  • Mode Switch sRGB
  • Product Number CMI-GM27-FQSA30TH
