GM27-CF Gaming Monitor image number 0
GM27-CF Gaming Monitor image number 1
GM27-CF Gaming Monitor image number 2
GM27-CF Gaming Monitor image number 3
GM27-CF Gaming Monitor image number 4
GM27-CF Gaming Monitor image number 5
GM27-CF Gaming Monitor image number 6
GM27-CF Gaming Monitor image number 7
GM27-CF Gaming Monitor image number 8
GM27-CF Gaming Monitor image number 9
GM27-CF Gaming Monitor image number 10
GM27-CF Gaming Monitor image number 11
Enter Gamersive Reality
Cooler Master GM27-CF is designed for gamers who are not willing to compromise their experience in both the gaming competency...
  • Curve 1500R
  • I/O - HDMI 2
  • I/O - Earphone Out 1
  • Anti-flicker Yes
  • Mode Switch Standard
  • Lighting Purple (Steady & Blinking modes)
  • VESA 75x75 mm
  • Tilt Adjustment -5°~+15°
  • I/O - DP 1.4 Cable 1
  • I/O - Speaker 2 (4Ω/3W)
  • Contrast Ratio 3000:1
  • Screen Type Curved Series
  • Monitor Series GM Series
  • Ratio 16:9
  • Mode Switch Graphic
  • Panel VA
  • Resolution FHD 1920x1080
  • Refresh Rate 165 Hz (overclock 200 Hz ± 5%)
  • Brightness 300 nits (Typical)
  • Color Gamut 90% DCI-P3 / 125% sRGB
  • I/O - DP 1
  • Response Time 3ms (GTG w/OD)
  • Height Adjustment 0-110 mm
  • Swivel Adjustment -15°~+15°
  • Mode Switch Movie
  • Screen Size 27"
  • Product Gaming Monitor
  • FreeSync AMD FreeSync Premium
  • Net Weight 5.13 kg
  • Mode Switch Game
  • Product Number CMI-GM27-CF
  • Gross Weight 6.81 kg
