GeminII M5 LED
The new GeminIIM5 LED low-profile CPU air cooler packs even more performance into its compact design with a red LED and five heat pipes
Heat Pipe DimensionsØ6mm
Fan Rated Voltage12 VDC
Cooler TypeAir Cooler
Fan MTTF40,000 Hours
Warranty2 years
Fan Power Connector4-Pin (PWM)
Fan L-10 Life40,000 Hours
Heatpipes5
SeriesGeminII
CPU SocketLGA1366
CPU SocketLGA1156
Heat Sink Material5 Heat Pipes
CPU SocketLGA1155
CPU SocketLGA1151
CPU SocketLGA1150
CPU SocketLGA775
Heat Sink MaterialAluminum Fins
Fan Dimensions (L x W x H)120 x 120 x 15 mm / 4.7 x 4.7 x 0.6 inch
Fan Speed500-1600 RPM ± 10%
Heat Sink Dimensions (L x W x H)130.15 x 120 x 45.5 mm / 5.12 x 4.7 x 1.8 inch
CPU SocketAM4
CPU SocketAM3+
CPU SocketAM3
Heat Sink MaterialDirect Contact
Fan Air Pressure1.3 mmH2O ± 10%
CPU SocketAM2+
Fan Rated Current0.18A
CPU SocketFM2+
CPU SocketFM2
CPU SocketFM1
Product NumberRR-T520-16PK
Fan Airflow50.43 CFM ± 10%
Fan Noise Level31 dBA (Max)
Dimensions (L x W x H)132 x 123 x 61.5 mm / 5.2 x 4.8 x 2.4 inch
