GA22FC image number 0
GA22FC image number 1
GA22FC image number 2
GA22FC image number 3
GA22FC image number 4
GA22FC image number 5
GA22FC
GA22FC
GA22FC
GA22FC
GA22FC
GA22FC
Your Everyday Work and Play Companion
GA22FC
The GA22FC is designed for office workers and gamers alike who want to enjoy a seamless and leveled-up everyday experience.
With a 21.45” FHD display, 4000:1 high contrast ratio, and a 100Hz refresh rate, the GA22FC meets the needs of both light esports and daily work. It is the perfect choice for an entry-level display with high-value performance.
EXPERIENCE BETTER GAMING SESSIONS
The Adaptive Sync feature ensures smooth visuals, even when the frame rate fluctuates.
All-Day Comfort
A low blue light display mode reduces the amount of potentially harmful blue light, while a flicker-free function provides a stable display, putting your mind at ease during long sessions.
MULTIPLE CONNECTIONS
Connect your devices with I/O ports consisting of:
• HDMI 1.4
• VGA
• Power
  • Product Number CMI-GA22FC
  • Screen Size 21.45"
  • Ratio 16:9
  • Screen Type Flat Series
  • Panel VA 16.7M
  • Resolution FHD 1920x1080
  • Refresh Rate 100 Hz
  • Contrast Ratio 4000:1
  • Brightness 250 nits (Typical)
  • HDR N/A
  • HDR Peak Brightness N/A
  • Dimming Zones N/A
  • Color Gamut sRGB 105% (Typ., CIE 1931)
  • Color Gamut DCI-P3 75% (Typ., CIE 1976)
  • Color Gamut Adobe RGB 73% (Typ., CIE 1931)
  • I/O - VGA 1
  • I/O - HDMI 1.4 1
  • Overdrive Technology Yes
  • Response Time 4ms (GtG)
  • Response Time 1ms (MPRT)
  • Eye Protection Low Blue Light (S/W)
  • Anti-flicker N/A
  • I/O - Speaker N/A
  • KVM N/A
  • PIP/PBP (Screen Split) N/A
  • Power Consumption 24W (Max)
  • VESA 100x100 mm
  • Tilt Adjustment -5°~+20°
  • Swivel Adjustment N/A
  • Height Adjustment N/A
  • Pivot Adjustment N/A
  • Cooler Master Enhanced Cooling Design N/A
  • Monitor Series GA Series
  • Product Gaming Monitor
  • Panel Type VA
