Elite Gold 850 image number 0
Elite Gold 850 image number 1
Elite Gold 850 image number 2
Elite Gold 850 image number 3
Elite Gold 850
Elite Gold 850
Elite Gold 850
Elite Gold 850
Elite Gold 850
• Supports ATX 3.1 and PCIe Gen 5.1 standards
• Ideal for RTX 50 GPUs
• Stable performance under high loads at up to 40°C
• Quiet rifle bearing fan for efficient cooling and low noise
• 850W output with 80 Plus Gold-certified efficiency
• Fully modular embossed cable design
• Reliable 10-year warranty
HIGH TEMPERATURE RESILIENCE
Operates reliably at up to 40°C, perfect for extended gaming, rendering, and overclocking.
Compatible with ATX 3.1 and PCIe Gen 5.1
ATX 3.1 delivers tighter voltage and current regulation with peak power support up to 200% of its rated output, making the Elite Gold 850 ready for the latest and upcoming mid-range GPUs.
RIFLE BEARING FAN
RIFLE BEARING FAN
Cooler Master Elite Gold 850 achieves over 90% efficiency at typical loads, helping reduce energy waste and minimize heat generation.
COMPACT FORM FACTOR
COMPACT FORM FACTOR
Unlike typical high-wattage PSUs that extend beyond 150mm, the Elite Gold’s compact design at 150mm or less ensures easy installation across a wide range of cases, making it ideal for space-conscious PC builds.​
The fully modular design comes with flat black cables that can be tailored to each build, offering enhanced grip and a premium look for easier management and a cleaner overall setup.
  • Product Name ELITE GOLD 850
  • Model MPX-8505-AFAG
  • Input Current 6 ~ 12A
  • Fan Bearing Rifle bearing
  • 80 PLUS Rating 80 PLUS Gold
  • Hold Up Time ≥ 11ms @ 100% Load
  • Regulatory cTUV us, CB, CE, FCC, BSMI, CCC, RCM, UKCA, BIS, RoHS2.0
  • ATX 24 Pin Connectors x1 = 1 (550mm)
  • EPS 4+4 Pin Connectors x1 = 1 (600mm)
  • EPS 8 Pin Connector x1 = 1 (600mm)
  • SATA & Peripheral 4 Pin Connectors X4(s) + x2(p) = 2 [400(s)+120(s)+120(p) mm]
  • PCI-e 6+2 Pin Connectors x3 = 1 (500+120mm), 1 (500mm)
  • 12+4 Pin Connectors x1 = 1 (650mm)
  • Series Elite Series
  • Watts 850W
  • 80 Plus Efficiency Gold
  • Warranty 10 Years
