Elite 690 Wood image number 0
Elite 690 Wood image number 1
Elite 690 Wood image number 2
Elite 690 Wood image number 3
Elite 690 Wood image number 4
Elite 690 Wood image number 5
Elite 690 Wood
Elite 690 Wood
Elite 690 Wood
Elite 690 Wood
Elite 690 Wood
Elite 690 Wood
Natural Aesthetics. Immersive View. Advanced Cooling.
Elite 690 Wood
The Elite 690 features dual tempered glass panels to showcase your build, while a wood-textured front accent and mesh intake blend warmth with airflow efficiency. With top and bottom ventilation for vertical cooling, it supports versatile fan and radiator setups—perfect for performance-driven or style-focused builds.
270° Panoramic Tempered Glass
Beveled glass panels create an immersive, seamless showcase of your build.
Optimized Tower with PSU Chamber
Vertical layout separates thermal zones for better airflow and cleaner cable routing.
Vertical Cooling Architecture
Up to 10 fans in a bottom-to-top layout maximize airflow and cooling.
Natural Wood Front Panel
Crafted from real wood, the front panel adds a warm, organic touch to any space.
High-Performance Radiator Support
Top 360mm and side 240mm radiator support for powerful cooling setups.
Pre-installed ARGB Fans with Sync
Includes 3 daisy-chainable ARGB fans with full motherboard lighting sync support.
Top & Bottom Mesh Ventilation
Mesh panels ensure enhanced airflow and system-wide thermal performance.
Next-Gen GPU Ready
Supports up to 425mm GPUs—ready for RTX 50 Series and beyond.
High-Speed I/O Panel
USB 3.2 Gen 2x2 Type-C and dual USB 3.0 ports for blazing-fast connectivity.
  • Model Number Black: E690-KHNN-S00, White: E690-WHNN-S00
  • Color(s) Black / White
  • Materials - Front Panel Tempered Glass + Wood
  • Material - Side Panel (Left) Tempered Glass
  • Material - Side Panel (Right) Steel
  • Dimensions (L x W x H) 434 x 218 x 454 mm (Incl. Protrusions), 430 x 218 x 435 mm (Excl. Protrusions)
  • Volume 42.93 L (Liters Incl. Protrusions)
  • Motherboard Support ITX / Micro-ATX / ATX
  • Expansion Slots 7
  • 5.25" Drive Bays 0
  • 3.5" Drive Bays 1 (Max. 2)
  • 2.5" Drive Bays 1 (Max. 2)
  • I/O Panel - USB Ports 1 x USB Type C 20Gbps, 2 x USB 3.0
  • Pre-installed Fans - Rear 1x 120mm ARGB PWM
  • Pre-installed Fans - Side Mount 2x 120mm ARGB PWM reverse fan
  • Fan Support - Top 2x 140mm / 3x 120mm
  • Fan Support - Rear 1x 120mm
  • Fan Support - Side Mount 2x 120mm
  • Fan Support - Bottom 3x 120mm
  • Radiator Support - Top 120 / 240 / 360 (Max height 45mm)
  • Radiator Support - Bottom 120 / 240 / 360mm
  • Radiator Support - Side Mount 120 / 240mm
  • Clearance - CPU Cooler 170mm
  • Clearance - PSU 250mm
  • Clearance - Graphics Card 425mm
  • Power Supply Support ATX
  • Size Mid Tower
  • Series Elite Series
