Global Headquarters
Built to Showcase, Cooled to Perform
The Elite 681 redefines showcase builds with its panoramic 270° tempered glass panels and true dual-chamber layout. Designed for high performance systems, it combines refined aesthetics with cutting-edge airflow engineering. From vertical cooling support to extensive radiator compatibility, this case is built to handle next-gen hardware with style and precision.
Dual tempered glass panels with 45° bevels offer an uninterrupted, ultra-clean view of your system and lighting.
Separate chambers for motherboard and PSU/cabling streamline airflow and simplify cable management with 95mm clearance.
Supports dual 360mm radiators (top & bottom) and one 280mm side radiator for custom loops or powerful AIOs.
Up to 10 fans with bottom-to-top layout accelerate heat dissipation for superior thermal performance.
Includes 4 ARGB fans (3 reverse intake + 1 exhaust) with daisy-chaining and full motherboard lighting sync.
Large mesh panels on the top and bottom provide maximum airflow for efficient cooling.
Supports GPUs up to 410mm, perfect for the latest next-gen graphics cards.
Features USB 3.2 Gen 2x2 Type-C (20Gbps) and dual USB 3.0 ports for fast and flexible connectivity.![]()
