Elite 600 image number 0
Elite 600 image number 1
Elite 600 image number 2
Elite 600 image number 3
Elite 600 image number 4
Elite 600
Elite 600
Elite 600
Elite 600
Elite 600
Elite 600
ATX mid-tower case with tempered glass, USB-C, and versatile cooling support for clean, efficient, and powerful builds.
Tempered Glass Panoramic Panel
Premium tempered glass side panel provides a clear, unobstructed view of your build, showcasing your components in a sleek, modern style.
Full-Size GPU Support
With support for GPUs up to 425mm in length, this case offers ample space for the most powerful graphics cards, ensuring smooth gaming and performance.
Supports Double 360mm Radiator
Built for high-performance setups, the Elite 600 supports up to two 360mm radiators, providing exceptional cooling for demanding builds.
Versatile Cooling Options
Designed for maximum airflow, the Elite 600 features multiple fan mounting points and radiator support, offering flexibility for air or liquid cooling solutions.
Radiators Support
Fans Support
USB 3.2 Gen 2x2 Type-C
Future-proof your build with USB 3.2 Gen 2x2 Type-C, offering ultra-fast data transfer speeds for modern devices and enhanced connectivity options.
Tool-Free Access Design
Quickly install and upgrade components with the tool-free design, providing easy access to the interior and making system builds and maintenance a breeze.
  • Product Name Elite 600
  • Color(s) Black / White
  • Model Number Global: Black: E600-KG00-S00, White: E600-WG00-S00
  • Model Number North America: Black: E600-KGNN-S00, White: E600-WGNN-S00
  • Model Number Black: E600-KGNN-S02, White: E600-WGNN-S02
  • Materials - Exterior SGPCC Steel
  • Materials - Side panel (Right / Left) Steel / Tempered Glass
  • Dimensions (L x W x H) 445 x 285 x 410mm(Incl. Protrusions), 445 x 285 x 400 mm(Excl. Protrusions)
  • Volume 50.73 L
  • Motherboard Support Mini-ITX, Mini-DTX, Micro-ATX, ATX
  • Power Supply Support ATX
  • Expansion Slots 7
  • 5.25" Drive Bays N/A
  • 3.5" Drive Bays 1
  • 2.5" / 3.5" Drive Bays (Combo) 1
  • 2.5" Drive Bays 2
  • I/O Panel 2x USB 3.1 Gen 1 Type-A, 1x USB 3.2 Gen 2 Type-C
  • Pre-installed Fans - Bottom N/A
  • Pre-installed Fans - Side Mount N/A
  • Fan Support - Bottom 3x 120mm
  • Fan Support - Top 3x 120mm / 2x 140mm
  • Fan Support - Rear 1x 120mm
  • Fan Support - Side 3x 120mm / 2x 140mm
  • Radiator Support - Bottom 240 / 360mm
  • Radiator Support - Top 240 / 280 / 360 mm
  • Radiator Support - Side 240 / 280
  • Dust Filters Top, Bottom, Right Side Panel
  • Clearance - CPU Cooler 160mm
  • Clearance - PSU 240mm
  • Clearances - Graphics Card L: 425 mm (incl. power connector), H: 160 mm (incl. power connector)
  • Cable Routing - Behind MB Tray 11mm
  • Series Elite Series
  • Size Mid Tower
