Elite 502 Lite image number 0
Elite 502 Lite image number 1
Elite 502 Lite image number 2
Elite 502 Lite image number 3
Elite 502 Lite image number 4
Elite 502 Lite
Elite 502 Lite
Elite 502 Lite
Elite 502 Lite
Elite 502 Lite
Effortless Efficiency
Elite 502 Lite
The Elite 502 Lite delivers exceptional cooling and performance with its advanced mesh front panel for enhanced airflow. Designed for mid-to-entry-level builders, it supports up to a 420mm radiator, 410mm GPUs, and modern back-connector motherboards, offering a streamlined and efficient building experience at an accessible price.​
Back-Connected Motherboard Support​
Supports back-connected motherboard design, freeing up space at the front of the case and providing 33-35mm of space behind the motherboard tray for easier cable management.
Basic Cooling Configuration​
Equipped with a single 120mm fan, it provides essential cooling while enhancing system airflow for improved performance and aesthetics.
USB Type-C Support
USB Type C port built into the I/O panel allows multi-purpose, streamlined data transmission. ​
ROOM FOR UPDATES​
Supports a 410mm GPU, a 170mm CPU cooler, and ample space for future hardware upgrades.
Versatile Thermal Options
Supports up to seven 120mm fans and either a top-mounted 360mm radiator or a front-mounted 420mm radiator, offering hyper-effective CPU thermal performance.​
Removable HDD Cage
The HDD cage is completely removable, providing better access during assembly and system upgrades.​
  • Product Name ELITE 502 LITE
  • Product Name ELITE 502 LITE White
  • Model Number ELITE 502 LITE: E502L-KGNN-S00
  • Model Number ELITE 502 LITE White: E502L-WGNN-S00
  • Color(s) ELITE 502 Lite: Black / ELITE 502 Lite White: White
  • Materials - Exterior Steel
  • Materials - Right Side Panel Steel
  • Materials - Left Side Panel TG
  • Dimensions (L x W x H) 474 x 230 x 481 mm(Incl. Protrusions), 465 x 230 x 465 mm(Excl. Protrusions)
  • Volume (incl. Protrusions) 49.73 L
  • Motherboard Support ITX / Micro ATX / ATX (Supporting Back-connector Motherboard) / E-ATX (*up to 12"x10.9"/ 30.5cmx27.7cm motherboards, may impact cable management)
  • Expansion Slots 7
  • 5.25" Drive Bays N/A
  • 3.5" Drive Bays 2
  • 2.5" Drive Bays 2 (Max.6)
  • I/O Panel - USB Ports 1x USB 3.2 Gen1 Type A, 1x USB 3.2 Gen1 Type C​
  • I/O Panel - Audio In / Out 3.5 mm Combo x 1
  • Fan Support - Front 3x 120 mm / 3x 140 mm
  • Fan Support - Top 3x 120 mm / 2x 140 mm
  • Fan Support - Rear 1x 120mm
  • Radiator Support - Front 120 / 140 / 240 / 280 / 360 / 420 mm (Limit: 457*140*27 mm)
  • Radiator Support - Top 120 / 140 / 240 / 280 / 360mm
  • Clearance - CPU Cooler 170mm
  • Clearance - PSU 170 / 210mm (w/o HDD Cage)
  • Clearance - Graphics Card (installed 3.5"HDD BRK) 360 / 410 mm (w/o front radiator)
  • Cable Routing - Behind Motherboard Tray 33-35 mm
  • Dust Filters Top, Front, Bottom
  • Power Supply Support ATX
