Elite 490 image number 0
Elite 490 image number 1
Elite 490 image number 2
Elite 490 image number 3
Elite 490 image number 4
Elite 490 image number 5
Elite 490
Elite 490
Elite 490
Elite 490
Elite 490
Elite 490
Compact Build, Bold Capabilities
Elite 490
The Elite 490 delivers a clean, modern aesthetic in a space-efficient mATX form factor. Featuring dual tempered glass panels on the front and side, it offers a wide, uninterrupted view of your build’s lighting and hardware. Despite its compact size, the Elite 490 supports full-sized cooling solutions with up to 360mm radiator compatibility and room for 9 fans—perfect for minimalist setups that demand performance.
270° Tempered Glass View
Front and side glass panels with beveled edges highlight your lighting and key components.
Compact M-ATX, Full-Scale Cooling
Smaller footprint fits tight spaces—without sacrificing radiator or GPU support.
360mm Radiator Support
Delivers high-end cooling typically found in full-size ATX cases.
Vertical Cooling Layout
Up to 9 fans enable bottom-to-top airflow for effective heat management.
Pre-installed ARGB Fans with Sync
Includes 3 ARGB fans with daisy-chain support and full motherboard lighting sync.
Top & Bottom Mesh Ventilation
Large mesh zones enhance airflow and cooling performance.
RTX 50 Series Ready
GPU clearance up to 425mm for next-gen flagship graphics cards.
High-Speed I/O Panel
Features USB 3.2 Gen 2x2 Type-C (20Gbps) and dual USB 3.0 for fast, modern connectivity.
  • Model Number Black: E490-KHNN-S00, White: E490-WHNN-S00
  • Color(s) Black / White
  • Materials - Front Panel Tempered Glass
  • Material - Side Panel (Left) Tempered Glass
  • Material - Side Panel (Right) Steel
  • Dimensions (L x W x H) 434 x 218 x 414 mm (Incl. Protrusions), 430 x 218 x 395 mm (Excl. Protrusions)
  • Volume 39.16 L (Liters Incl. Protrusions)
  • Motherboard Support ITX / Micro ATX
  • Expansion Slots 5
  • 5.25" Drive Bays 0
  • 3.5" Drive Bays 1 (Max. 2)
  • 2.5" Drive Bays 1
  • I/O Panel - USB Ports 1 x USB Type C 20Gbps, 2 x USB 3.0
  • Pre-installed Fans - Rear 1x 120mm ARGB PWM
  • Pre-installed Fans - Side Mount 2x 120mm ARGB PWM reverse fan
  • Fan Support - Top 2x 140mm / 3x 120mm
  • Fan Support - Rear 1x 120mm
  • Fan Support - Side Mount 2x 120mm
  • Fan Support - Bottom 3x 120mm
  • Radiator Support - Top 120 / 240 / 360 (Max memory installation height: 45 mm)
  • Clearance - CPU Cooler 170mm
  • Clearance - PSU 250mm
  • Clearance - Graphics Card 425mm
  • Power Supply Support ATX
  • Size Mini Tower
  • Series Elite Series
