Elite 431 image number 0
Elite 431 image number 1
Elite 431 image number 2
Elite 431 image number 3
Elite 431 image number 4
Elite 431
Elite 431
Elite 431
Elite 431
Elite 431
Elite 431
Elite 431
  • Panel Transparent acrylic side panel window
  • Legacy Cases
  • Color(s) Black
  • Size Mid Tower
  • Cooling System - Top 120mm fan x 2 (optional)
  • Cooling System - Bottom 1x 80/90/120mm Fan (Optional)
  • Cooling System - Rear 80/90/120mm fan x 1 (optional)
  • I/O Panel 2x USB 2.0
  • Expansion Slots 7
  • Motherboard Support ATX
  • Power Supply Support Standard ATX PS2 (optional)
  • Series Elite Series
  • Materials Steel body
  • Cooling System - Front 120mm blue LED fan x 2 (installed; with LED on/off)
  • Maximum Compatibility - CPU Cooler Height 163mm / 6.4 inch
  • Cooling System - Front or 140mm fan x 1 (optional)
  • Weight 4.8 kg / 10.6 lbs
  • 5.25" Drive Bays 3 (exposed)
  • I/O Panel 1x Mic
  • Maximum Compatibility - VGA Card Length 315mm / 12.4 inch
  • Materials ABS Plastic
  • 3.5" Drive Bays 2 (exposed)
  • 3.5" Drive Bays 5 (hidden)
  • Dimensions (L x W x H) 192.5 x 427 x 498.3mm / 7.5 x 16.8 x 19.6 inch
  • Model Number RC-431
