Elite 371 image number 0
Elite 371 image number 1
Elite 371 image number 2
Elite 371 image number 3
Elite 371 image number 4
Elite 371
Elite 371
Elite 371
Elite 371
Elite 371
Elite 371
Elite 371
  • Color(s) Black
  • Size Mid Tower
  • Legacy Cases
  • Cooling System - Side 120/140mm fan x 2 (optional)
  • Cooling System - Top 120mm fan x 2 (optional)
  • Cooling System - Bottom 1x 80/90/120mm Fan (Optional)
  • Cooling System - Rear 120mm fan x 1 (installed, 1200 RPM, 17 dBA)
  • I/O Panel 2x USB 2.0
  • Expansion Slots 7
  • Motherboard Support ATX
  • Power Supply Support Standard ATX PS2 (optional)
  • Series Elite Series
  • Materials Steel body
  • Maximum Compatibility - CPU Cooler Height 163mm / 6.4 inch
  • Cooling System - Front 120/140mm fan (optional)
  • Weight 4.6 kg / 10.1 lbs
  • Net Weight 4.6kg / 10.1 lb
  • 5.25" Drive Bays 3 (exposed)
  • I/O Panel 1x Mic
  • Maximum Compatibility - VGA Card Length 315mm / 12.4 inch
  • Materials ABS Plastic
  • 3.5" Drive Bays 1 (exposed)
  • 3.5" Drive Bays 5 (hidden)
  • Dimensions (L x W x H) 190 x 424 x 481 mm / 7.5 x 16.7 x 18.9 inch
  • Model Number RC-371
