Global Headquarters
Built to Perform. Designed to Display.
• Open Showcase Stage
• 10.1” HD Screen
• Hot-Swappable & Removable Showcase Module
• High-Speed Front I/O
• Compact Volume Design
• Powerful Compatibility
The Elite 360 blends minimalist design with an open showcase concept, turning your PC into part of your desktop display. A dedicated showcase stage and integrated 10.1" screen bring personalization front and center, while spacious hardware support keeps performance uncompromised.
Your Build. Your Stage.
A dedicated front display chamber gives your favorite figures, collectibles, and personal touches a place beside your build.
Make It Yours.
Display system information, animated wallpapers, or custom visuals on the integrated 10.1" 1280 × 800 screen.
Swap. Style. Refresh.
The modular showcase chamber is removable and hot-swappable, making customization, cleaning, and reconfiguration effortless.
Speed Within Reach.
One 20Gbps USB Type-C port and dual USB 3.0 ports deliver fast, convenient connectivity for your everyday gear.
More Build. Less Footprint.
At just 39.16L, the Elite 360 makes efficient use of desk space while leaving plenty of room inside for powerful hardware.
Ready for Big Hardware.
Support for GPUs up to 425mm, CPU coolers up to 170mm, and ATX power supplies up to 250mm gives you room to build without holding back.
Cooling Built to Scale.
Top-mounted radiator support up to 360mm gives high-performance builds the cooling headroom they need.
Performance on Display.
A gray tempered glass side panel puts your hardware on show while complementing the Elite 360’s clean architectural design.
